NinerBikes
Jul 30, 2014Explorer
A single 100 amp battery limits you to, at most, 50 amp hours in a 24 hour period. 120 to 140 watts of portable, aimable, solar panel, with you having only one battery, and a good charge controller that's adjustable in voltage to 14.4 to 14.5V at the battery terminal, not the charge controller, after wiring voltage losses, should get that back for you.
Note also, that AGM batteries like high charge rates, see the manufacturer's charge rate recommendations, before you buy a charger.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
