NinerBikes
Jul 31, 2014Explorer
greenrvgreen wrote:
I need a 15 amp portable charger that I can run from my 450 watt inverter gennie. Battery bank will be right around 100 ah, AGM batteries. Here are some possibilities I found on Amazon:
This:
http://www.amazon.com/Schumacher-SSC-1500A-CA-SpeedCharge-Charger-Battery/dp/B000H961YI/ref=sr_1_1?ie=UTF8&qid=1406678767&sr=8-1&keywords=15+amp+battery+charger
Also this:
http://www.amazon.com/Duracell-D15A-AMP-Battery-Charger/dp/B000U0O6BE/ref=sr_1_2?ie=UTF8&qid=1406678767&sr=8-2&keywords=15+amp+battery+charger
And this too:
http://www.amazon.com/Stanley-BC1509-Automatic-Battery-Charger/dp/B001U04MSU/ref=sr_1_3?ie=UTF8&qid=1406678767&sr=8-3&keywords=15+amp+battery+charger
Oh, and this expensive and heavy one that I've already got in a 45 amp:
http://www.bestconverter.com/DLS-15-15-Amp-Power-Converter_p_316.html
I'd love to go with a larger charger but I'm constrained by the 450 watt streaming capacity of my little gennie (Powerhouse). Ideas? Thanks!
I think your approach is a little bit backwards thinking. Most of the experienced folks here don't top off the battery in the evening, that's a job for a solar panel system. A generator and charging batteries is best done first thing in the morning, when the batteries are low in charge, where a generator and battery charger do the most benefit to the battery, in the least amount of time on the least amount of fuel.
Most prefer to top off charge a battery with a solar panel.
You've placed some severe limits on your ability to recharge efficiently by buying such a low capacity generator with only 3.75 amps at 120v output. A 1000 watt generator would have been better, as well as an inexpensive 30 amp 12v power supply, like the Mega Watt or Mean Well units.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
