NinerBikes
Jul 31, 2014Explorer
greenrvgreen wrote:
You talkin bout this, Mex:
http://www.ebay.com/itm/NEW-IN-BOX-Meanwell-RS-50-15-15-Volt-3-4-amp-enclosed-power-supply-/220925352430
If so, how doth I tweaketh it? It looks darn untweakable in that pic. Certainly the price is right. And you're right, I don't want a "smart" charger, I want a dumb charge source that I can sit there monitoring.
Er, I'm going to have to smarten up about how not to overcharge AGMs.
ETC:
I fully realize I'm doing it backwards, but I have need of overnight power (fan) and often have constraints on my morning gennie usage.
Regarding larger gennie, every pound counts, as well as every dollar. The 10 extra pounds on the Honda (and 700 extra dollars) is that much more weight I have to pack and possibly drag in a snow sled, although I haven't gotten to that point yet.
Nope, that's 3.4 amps output.... you want 15 amps output, at 15V, and yes there should be a tiny screw, yellow in color, a potentiometer screw, to adjust voltage on the unit.
Understand you can't leave this unit exposed outside to the elements like rain, snow, etc. It needs to be in an enclosed area, away from the elements.
Something like this is closer.... , needs to be closer to having 15.0V capability, so you can back it off and adjust it down to 14.4V for your AGM battery.
15V 15Amp
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
