KJINTF
Jan 03, 2015Explorer
2 x 140 = 280 watts /13.2 (Floating voltage / Bulk with higher voltage will reduce the output current) = > 20 amps
Actually many quality panels are under rated
Many of them can & do easily exceed their rated outputs
140watt / 8amps = 17 Volt Vmp
Have to assume you have a PWM controller
An example my 550 watts / 13.2 = Give me in excess of 40amps to the loads under good conditions but NOT to the batteries they never need that much
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
