BFL13
Jan 07, 2015Explorer II
Salvo wrote:
Sure, once it gasses at 16V, it's probably zero percent. However in absorption, AH will be close to 100%, while WH is much lower. The surface charge voltage, battery and cable resistance all eat up watts, resulting in WH errors.
Barre says "gassing voltage" starts around 14.2v. Your curves on voltage where it take a jump are related to that AFAIK.
There are AH errors too, so I don't agree (at this stage anyway.) Check out the blurb in the Trimetic manual eg.
http://www.bogartengineering.com/sites/default/files/docs/TM-2025%20Users%20Instructions9-11-12.pdf
Page 10 of 16. Ref to "charge efficiency" factor P10. Also para 6.2 and 6.22 part 4
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
