vandave's avatar
vandave
Check engine light
Why does my 2017 Ford V-10 check engine light stay on?
  • wnjj's avatar
    wnjj
    Explorer II
    John Wayne wrote:
    Buy a Scan Gauge II read and clear your codes and get other information like trans temp. and more.
    A $10 bluetooth OBD2 scanner + Android cellphone/tablet + "Torque" App = a scanner good enough for reading/clearing most codes.
  • The check engine light means that something is wrong. Buy a code reader or find someplace that will read it for you. It could be a simple fix or a costly one, but get it checked out. Or electrical tape over the light.
  • Buy a Scan Gauge II read and clear your codes and get other information like trans temp. and more.
  • Most auto parts stores, and WalMart, have the ability to retrieve codes. Should be able to find a lot you’re able to pull into.
  • Yes. As always it should be near the stearing column under the front edge of the dash.
  • Thanks for the replies. I doubt I can gat my Motor Home in the auto zone lot. Do new, class A MH with the V-10 have a port to hook diagnostics to?
  • Agree'd you need to read the code(s).
    Could be as simple as a loose gas cap.
  • Cause you are supposed to get the code read and go from there... :)
    Good luck!
    Mitch
  • You have a stored error code. Go to autozone and have then read it. With that code you can look up possible causes.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
