profdant139's avatar
profdant139
Explorer II
Nov 28, 2020
Check water level on new battery! And screw-on lids??
Just got two new batteries today from NAPA -- brought them home and checked the water. Each cell needed about two ounces of distilled water.
I'm guessing that they ship them with low water so that they are less likely to spill during shipment. So my point is that you gotta check 'em yourself. My guess is that anyone reading this already knows that! ;)
Also, these batteries had screw-top fill ports. I am used to the snap-on, snap-off lids, in which three cells are exposed at one time. These screw-on lids were one per cell. A little tedious to unscrew each one, instead of popping the cap.
But I think that they provide a better seal. (I assume that there is some sort of a safety valve so that the battery can outgas when needed??)
  • Charge first if plates are not exposed.
    Since it is a little late to take fluid out--monitor the levels as you charge the batteries.
  • You may have overfilled them. Most marine/RV batteries are full 1/4” to 3/8” below the ends of the split tubes. Avoids splash out during bouncing and charging.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    did you fully charge them before checking water level? If not you may have overfilled them. Water level should be checked on a fully charged battery. Water level will go down as the battery discharges.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
