RJsfishin
Dec 11, 2015Explorer
Oasisbob wrote:
I do not believe the people on assembly line installing electrical are certified electricians. It is all about speed not quality so I have seen
Exactly !!
The annual inspection for loose screws is not going to happen among 95% of RV'ers, (nor does it have to) so we can forget that.
I have run into a lot of loose connections in my life, but NONE that I had ever installed or tightened many years before.
I nearly lost a 200 amp box on my new home, at about 1 yr old, and all installed by a genuine elec tech. Had weird stuff happening under heavy loading,,,,A/C etc. Went looking, and when walking by the main panel, sounded like an arc welder inside,.....all because one allen screw in a buss bar. And don't even try to tell me that it was ever tightened correctly from day one. Did I need to inspect the elec tech's work ?? YES ! And only because the inspector for the electrical permit sure didn't !
My advice,...check all the connections for tightness maybe twice, a few days apart from each other, tighten them correctly,......or as tight as possible ????? They will not come loose, even if you go stump jumpin in your RV.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
