chuggs
Oct 13, 2014Explorer
The Teflon gets cut by the threads when tightened...don't worry none, it will conduct to the tank just fine. If you read the installation instructions on the anodes wrapper...it says to use Teflon tape or joint compound safe for drinking water...
Just finished bleach sanitizing my fresh water system, flushing the hot water tank, and replacing my anode. I can get two years out of a magnesium anode usually...it just depends on your water.
They say...if your magnesium anode doesn't last a full year...then you then should switch to the Aluminum ones.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
