Dakota98
Nov 22, 2014Explorer
JiminDenver wrote:
How far? It would be cheesy but I'd just extend the leads on a cheap voltmeter into the house. there would probably be voltage drop but you could gauge that to just make sure the battery was staying up. Bt the time you noticed a light not being on, your battery would be dead.
X 2
Here's one that should work. Just extend the leads directly to the battery or attach a male 12 volt connection & run it through a window into the coach 12 volt receptacle.
VOLT METER
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
