JoeH
Jan 14, 2021Explorer III
Gdetrailer wrote:JoeH wrote:Tom_M wrote:
Switch your meter to AC and check. Most likely one supply is AC and the other is DC.
Nope-- meter stays on "0" regardless of being on AC or DC.... but the LED lights out in the yard work. Strange
Post a pix of the power supply with the model number..
I suspect it is a high frequency switching supply and has no or little filtering on the output.. Most meters will not read at all or properly 15Khz-30khz frequencies which most switching supplies operate at which could explain why you can't get a reading but the lights work.
I'll get a pic soon---- sounds like you might have solved it.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
