sbodi4d's avatar
sbodi4d
Chevy with brake controller problem.
Went to pick up my new Pup at the dealer yesterday, but they could not get the brake controller to work on my truck for some reason. I have a 2007 Chevy Silverado 1/2 ton new body style. I think they said they had power to the controller, but nothing back at the seven way plug. They told me there must be something wrong with the factory wiring harness, and to take it to a Chevy dealer to get it checked out. He said it would flicker on, but not stay on, so he thinks the controller is good, but I think it may be a bad controller. All I know right now is it is a Tekonsha controller. Not sure what model or anything, but they charged me $175.00 for the controller with installation.
Anybody had trouble hooking up a brake controller to a Chevy? The only thing on the truck that isn't factory is a Leer camper top that I had installed two or three years ago. The high mount brake light on the camper top doesn't work some times, but it works most of the time. The inside light for the camper top has never worked, but I was going to look at it sometime to see why. I don't think that has anything to do with the brake controller, but I have seen some strange electrical stuff before. Any input would be appreciated.
  • I installed a P3 controller in my 07 (new body style) last year. Chevy runs the wiring for a brake controller but doesn't connect the powere feed wire to the terminal stud at the front of the fuse box in the engine compartment and doesn't supply the fuse needed to power that wire. Did the dealer add the fuse in the engine compartment box that is not installed from the factory? They should have also hooked up the power wire for the controller to one of the studs at the front of the same fuse box...that wire is unhooked and usually taped to another harness from the factory. Here is a 2006 examplebut should give you an idea of what to look for.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
