Alxcook's avatar
Alxcook
Chevy Workhorse 8.1 going into limp mode
Just looked, I haven't posted in 10 years, time flies.
I have a 2004 pace arrow with 8.1 Chevy, I am getting engine code P0131, which puts the engine into a fail safe mode, thus losing power. My question is pretty simple, just can't find anyone that thinks I am on the right track.
It started in the Fall on a trip after I got gas, and then it went away after I got gas again, then came back after I got gas again..........sounds simple, maybe a gas cap.
So I buy a new gas cap, worked great for another 1200 miles of towing, then it happens again under load. I mess with gas cap, it goes away for 150 miles and then on a long climb it comes back.
The code says it is a lean condition on the left side o2 sensor, I replaced that as well.
So my question, am I on the right track with the gas cap? If it isn't sealing correctly, it can't create a vacuum, thus the computer will throw an engine code?? Can't find anything on the internet to confirm this theory.
This has only happened under heavy towing on a hill as well. Clear code and it goes away, until the next climb.
Any ideas appreciated,.
  • wnjj's avatar
    wnjj
    Explorer II
    Two different replies here said cleaning or replacing the MAF sensor cured their issue. For what it’s worth I just replaced the one on my 2005 8.1l. I was getting p0101 when pulling grades after a gas stop It turns out the MAF test only runs when near WOT and it takes 2 consecutive failed tests after restarts. That’s why mine also seemed to track with gas stops followed by grades.
    It has under 40k miles but obviously they age out. I tried cleaning first then replaced it and the MAP sensor. No more codes. Just over $100 for both if I remember correctly. Granted, mine may have been the MAP sensor but I wanted the issue gone and "testing" was only during infrequent trips.
  • Do you have a exhaust manifold leaking on that side? Have fuel trims checked.
  • There are numerous possibilities. If you know of a good mechanic with a top notch scan tool they can look at fuel trims and other data to narrow the actual issue down.
    Common causes for the P0131 code can be from the 02 sensor which you already replaced to fauty sensor wire harness, a clogged fuel filter, fuel pump going bad, leaking exhaust at the donut, Intake air leaks, faulty injector, etc....
Having RV issues? Connect with others who have been in your shoes.24,246 PostsLatest Activity: May 13, 2025
