tenbear
Aug 26, 2013Explorer
It sounds like your converter is shot or you have some loose contacts.
I had a Parallax/Magnetek 7345 converter, a single stage 45 amp converter that charges at 13.8v. You should look at your converter and see what the rating is. I replaced mine with a PD 9260. Its a 3 stage 60 amp converter. It charges the battery much faster. The PD 4600 series are plug and play replacements for the Magnetek converters.
I would check the connections to make sure they are tight before replacing the converter.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
