wa8yxm
Aug 26, 2013Explorer III
SkiSmuggs wrote:
I'm thinking the Intellipower converters with the Charge Wizard.
You are thinking wisely grasshopper.
Though there are many that would rank either as good as the Charge Wizard controlled units from progressive Dynamics and even more so close as to not matter.. NONE would I rank better.
NOTE if your converter is part of your power distribution panel. You need not replace the panel.. You can just add like a 9200 to the system. (Optionally gut the existing converter to save weight or keep it around (Just disconnect the 120 volt lead to it) "Just in case".
Next question ... how big a converter (30-40-50-60-70 amp)
This depends on your batteries.. Take the amp hour ratings of your 12 volt battery(s0 (If you have six volt pairs treat each pair as a single 12 volt battery, for everything) and add 'em up
Two group 27, for example is roughly 190-100 amp hours.
Multiply by zero point three (0.3) or 30%
200 times 30% = 60
That is your converter size.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
