Is the picture you posted the new circuit board you bought to replace the broken board?
I found this one that looks similar other than it has two more circuits..
found
HERE that one is for Magnetek/Paralax 6300/ 7300 series converter panel.
You might be find exact replacement if you search for the name and model of converter panel box you have.
However, your fuse block may have been discontinued and if that is the case you may need to use retrofit fuse panels which will not be a direct fit and will require some modifications to fit.
Barring the searching, you could try contacting
BEST CONVERTEROtherwise I do have several other suggestions, there are add on ATC fuse panels you can use if you have the space and depth..
These are nice since they can be surface mounted directly to metal with no electrical isolation needed..
In the case of converter use, you use one of the fuse positions for the converter fuse and the stud would be the battery connection.
That one is a Blue Seas so it is a bit expensive..  Found
HEREAnother version..
If you need a negative termination you would need to do some digging but there may some of those types of fuse blocks that offer a negative termination also.
