BFL13 wrote:
jimdmorrison wrote:
https://letusdisagree.com/wp-content/uploads/2021/04/circuit.jpeg
Has the #'s 1 21130
I need to replace my circuit board, but the replacement one I got was too big and didn't have screw holes in the right place. Any recommendations on which one I should be looking for? I need the screw holes to mount it or it will touch the metal.
The photo in the OP is of a 6300's fuse panel as seen here:
https://www.bestconverter.com/Magnetek-Upgrade_ep_26-1.html
But, obviously THAT board is obsolete and no longer "available", you have to use the aftermarket "replacement" 6300/7300 board which is not OEM and is pictured in this photo from Best Converter.
Obviously, the OP did not buy fuse board from Best converter and the board they got is DIFFERENT enough that the mounting holes are not in the same place.
What board they bought?, don't know since they didn't post pix of that board.
If OP would have bought the "kit" from Best converter, they would have gotten a new fuse board, but, looking over Bestconverter website, they do not show that board for sale as a separate item..
Here is link to fuse panels..
HERE which just shows a simple 10 position buss bar with no fuses.
OP should try contacting Best Converter to see if they can get the correct upgraded fuse panel that fits, otherwise they simply just need to do some surgery to their panel to make what they have work.
