DutchmenSport
May 08, 2018Explorer
If a cow ripped the spigot out of the ground, more than likely the same cow ripped the entire assembly out of the wall of your camper. If that's the case, a simple replacement won't be so easy. More than likely the wall itself is damaged where the assembly got yanked. Screw holes are probably all stripped and and possibly the wall itself could be broken. It's possible the plumbing inside the camper is stretched, and joints could have broken. Depending how tangled the cow got, and how frantic it became to free itself, the bathroom sink itself could have been yanked out the wall attached to the plumbing as the cow was yanking the hose.
OK, I'm exaggerating a bit. You can calm down now. Still, don't be surprised if where the assembly actually attaches to the wall on the outside, there is damage to the wall. You won't know until you get there and see it.
Good luck! And, when we drive by and see you taking a shower in the cow pasture, well... we'll all know why now! :)
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
