wnjj
Oct 22, 2020Explorer II
The pump normally prevents water from being pushed through it into the tank but sometimes a piece of debris can stick in it and cause it to leak. Using the pump may have already cured your issue. If not you may have to take apart the pump head and clean it. Worst case you need a pump rebuild kit, new pump or install an extra check valve after the pump output.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
