CJW8
Sep 28, 2016Explorer
Assumption: 50' one way, grounding through the frame. If it used to work fine and now doesn't, disconnect and clean each connection including converter to frame ground and frame ground to battery. Visually they may look "good" but there can be corrosion that you cannot see.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
