MEXICOWANDERER
Sep 28, 2016Explorer
I keep harping the point.
One tenth volt difference (under load) between a soldered joint and an oxidized crimp joint TIMES TEN connections equals ONE volt. Check VOLT DROP across EACH connection...
NO not terminal to terminal
Copper wire to copper wire
While under MAX load
And you will see.
How many connections between power origin and the lead battery posts?
Supervising Armando, I repaired many large motorhomes so that total voltage drop under high amp full load was .3 or less.
And you will see.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
