MrWizard
Sep 28, 2016Moderator
not sure where is the circuit the disconnect is, but should be .. between the batteries and everything else
also i'm 99% sure the converter wires goto the battery Not the distribution panel
other wires run from the batteries to the panel
any RV that has an inverter charger the distribution panel and charger are seperate units NOT combined
NOW if you have converter only no inverter, and the breaker panel is down on the floor, thats different, thats old combined style
yes it is still in use, but NOT where you have inverter/charger combo units
only in some 30amp converter only RVs
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
