Tripalot
Aug 02, 2014Explorer
We have a C or a pregnant B+, whatever you want to call it mounted on a Ford E450 chassis with the Firestone Airbags and on-board compressor. fortunately I didn't have to mount the stuff but perhaps the following will help.
The compressor, solenoids etc. are all mounted on a separate board and the board was then mounted in the rear compartment which houses the black and gray dump valves. this keeps it out of the way and out of the weather. Air lines were run from there to the two airbags and also up to the dashboard to supply the pressure gauge and controls.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
