ajriding
Mar 10, 2022Explorer II
Taking the box apart is not at all high tech. No hourly employee is needed, you can re-tape it yourself just as well as an RV guy who hurries thorough it. Duct tape is literally made for AC ducts and sealing off air. Use the shiny metal-looking tape, not the dull gray tape. If you need foam then reuse what you removed or use anything similar. This is one of the least complex systems on your RV, all you are doing is sealing off very very low pressure airflow.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
