What is the recommended way to clean an awning? Mine has gotten a bit of mildew, especially on the underside, and soap and water don't quite do the trick. Would bleach damage the fabric?
We use Simple Green and water. I get under there with a brush with a long handle and scrub till the mildew is gone. Then spray it off with the hose. Please note: You will get wet using this method.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
