What is the recommended way to clean an awning? Mine has gotten a bit of mildew, especially on the underside, and soap and water don't quite do the trick. Would bleach damage the fabric?
Like others a mix of water, bleach, soap. I use a 2 gallon yard sprayer, wear old clothes, and spray the underside with the mixture and let stand for 5-10 minutes. Then spray off with hose. Any remaining areas are re-sprayed and hit with a soft brush.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
