hhornig's avatar
hhornig
Cleaning Refrigerator Chimney
The water heater chimney usually rusts with time and use. I have seen recommendations to clean it with a flue brush, but the chimney has baffles in it and it is fairly narrow especially near the bottom. Does anyone know how to clean the chimney and where you can buy an appropriate flue brush?
  • Thanks for the info. Your Link shows a flue brush part no. I also noted the chimney should be cleaned annually. Mine hasn't been cleaned in 10 years; I hate to admit. After cleaning the burner it froze ice cubes in less than an hour. I don't know if that is bad or good, but I am satisfied.
    Old-Biscuit wrote:
    You don't mention which Brand or Model.....
    Here is a service manual for various Dometic Models.
    Flue cleaning is explained on pg. 20
    Very typical regardless of which fridge........LINK
  • j-d's avatar
    j-d
    Explorer II
    Bottle brush is better than nothing. Construction supply places have brushes for cleaning out holes drilled in concrete prior to epoxying fasteners in. Some are nylon bristle but there should be metal bristle ones too.
    Problem is, the BAFFLE hangs from the top of the flue. The best way to clean the flue is remove the Burner at the bottom, then go to the Roof. Pull the Baffle and clean with Wire "bottle" brush down from the TOP. Clean up where the Burner was, make sure no flakes in anything, reassemble. Don't forget the Baffle. But at least on our coach, even when I take the rain shield off of the fridge vent, the screen is one piece with the rest. I'm unwilling to remove the whole vent assembly from the roof.
    So... I do what a tech suggested. Reach up in from the bottom, past the burner to where the flue extends above the insulation pack. Rap on the Flue with a Screwdriver Handle. Pull the Burner and clean p whatever fell down and call it good.
    Thinking about this, if the top of the Flue clearly lines up with part of the plastic "mesh" of the plastic Vent Cover... Cut a section of the mesh out, reach down with coat hanger to fish the baffle up. Clean Flue with Brush extended with Coat Hanger. Lower Baffle back in and be sure the wire hooks to the flue top. Reattach the cut mesh. ZIP Ties, wire, little metal bracket etc.
  • I took the approach of the whole chimney. Pulled off plastic cap roof and was amazed at how much stuff was caught just under cap and under the screen. Didn't look like much until I looked down with a flash light. Between a un-bent hanger (to get under the screen) and a leaf blower it is now clean top to bottom. I also "scotch brite" pad the contact points and gave the chimney a couple of gentle swats with hand to get junk out.
    I really don't think there is any danger of fire. If there was we would hear about people melting their plastic roof cap, but wonder about efficiency of chimney with it being somewhat blocked. My neighbors trees don't help.
    Anyway and after cleaning it out and cleaning contact points runs 100% better. There is also some youtubes on cleaning and giving it a "tune up".
    Also picked up the plastic coupler thingies that keeps frig access panel against RV, just in case one of the two little plastic knobs broke. There is not a lot keeping them on.
  • You don't mention which Brand or Model.....
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
