agesilaus
May 22, 2019Explorer III
LittleBill wrote:
hi folks, clear as glass ice cubes are made by freezing water that is in constant movement, air is what causes the cloudiness, not the water content
That's correct the dissolved gases make it cloudy. If you have a tank of helium you 'sparge' the water with helium, bubble the helium thru the water using one of those aquarium bubbler stones and that will remove the gas from the water. Distilled water might help.
I've also heard that freezing the water in thin layers works but could get very tedious. I assume that allows the gas to escape as the water freezes.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
