GordonThree
May 22, 2019Explorer
agesilaus wrote:rockhillmanor wrote:
Boiling water only kills the bacteria. it won't eliminate the particulates in water. That is what clouds ice cubes, the more cloudy the cubes are the more junk is in your tap water! :B
If you have tap water that filthy you have other problems in a very big way. You must have been listening to the Culligan adverts, which are as close to lies as they can get away with. I was trained as an environmental engineer if you want to question my expertise. The Culligan adverts lie in other ways, have you ever considered how stupid it is to remove Calcium and magnesium from your drinking water and add Sodium (which is supposedly bad for you). And TAKE Calcium/Magnesium pills at the same time??
That sounds too much like common sense, it can't be true!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
