agesilaus
Jun 07, 2019Explorer III
MrWizard wrote:
Hot water will lose heat faster than cold water. (It has more heat to lose)
It does not freeze solid any faster than a equal amount of cold water when placed in the freezer at the same time
Rather amazingly this is not the case. I would have agreed with you not so long ago but then the Mpenda Effect happened. Some youngster actually tested this and got people to listen to his results.
Any chemist will tell you that water is a very strange material that behaves in a way that is the opposite of what is expected. Ice floats for example, not the normal. If not for this Oddity Life would not exist here.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
