1995brave
Dec 11, 2017Nomad
Since you are having the inside spray foamed you might want to put all the wiring into flexible tubing a little larger than the cable diameter (1/2 inch split loom would be good) in case you need to run more wire or replace a bad one.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
