Elwoodj
Apr 29, 2018Explorer
Clearview HDTV Antenna
I just read an article about how great the clearview hdtv antenna is and how it is better than cable or satellite. Further it could be free for seniors. Does anybody know anything this?
jkwilson wrote:dougrainer wrote:rk911 wrote:
pretty much accurate, Doug, except for this:
"...you probably will NOT receive OTA reception unless you have a roof top powerfull Digital type antenna..."
there is no such thing as a 'Digital type antenna'. the OTA antenna, roof, rabbit ears, etc. you were using the day before analog TV went dark is the same antenna you could use the next day to receive digital transmissions. TV antennas are designed for a specific frequency range and not modes of transmissions. the TV receiver (your TV set) decodes the transmissions and displays the picture.
I disagree. Winegard has for years a Wingman add on for better Digital reception. I purchased a RCA specific Antenna(about 24 inches long oval about 4 inches across and 1 inch deep) 10 years ago to the various digital broadcasters in my DFW, Texas area. The reception is fantastic and this antenna was marketed for Digital enhancement. MOST communities restrict (prohibit) roof top VHF/UFH dipole antenna's that everyone had 70 years ago until 2008. Those were large Di pole antenna's and very hard to install in the attic, which I did. The antenna I purchased(RCA) sits in the attic and receives both analog and Digital as well as that large Di pole I had and took down. Doug
As an engineer, I can assure you there is no such thing as a digital antenna or HDTV antenna. The channels used now are the same as channels used before, the numbers just don't translate into frequencies as they used to. What is now Channel 2 in one area may be broadcasting where Channel 63 used to be. A 50 year-old antenna will work just fine for HDTV. Any claims to the contrary are at best misleading.
Lynnmor wrote:
I’m so old that I remember when color tv antennas were marketed.
