landyacht318
Dec 21, 2018Explorer
While I have no idea what you are drilling, or intending to drill, I can guess.
I have a 90 degree attachment on my Dremel, and replaced the standard 1/8" collett with a drill type collett that can clamp down on a 1/64" drill bit and even smaller tightly, with no issue.
I pretty much NEVER remove the 90 degree attachement from the dremel, as it allows for so much more precision with just about any tool head I am using, and the tiny drill bits in the tiny drill chuck, well I most recently used it to drill through the solder which remained in the circuit board when I removed a 10K ohm trim pot so I could install wires into a new 5 amp voltage bucker which I use to speed control a 7000 rpm Delta fan.
Seriosuly the 90 degree dremel attachment is So much better, I have only removed it once, and the drill type attachemnt/chuck for the dremel is a thousand times more usedful than the 1/8" inch standard, that I pretty much NEVER remove that either, unless access is dificult as it is a wider diameter.
5k minimum dremel rpm is a lot for a drill but I've had no issues goin through solder, or wood, or fiberglass, or PLA, or carbon fiber with it.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
