TucsonJim
Sep 18, 2014Explorer II
Mine would usually only go off if the battery voltage was starting to get low. Even though you state that you're plugged in, you might want to measure your battery voltage before you start replacing parts. Who knows, it could be a converter problem and the detector is the first item to give you a signal.
