nehuge
Mar 13, 2023Explorer
enblethen wrote:
First couple items to check
Fuse or circuit breaker near battery
Fuse in 12-volt dc distribution panel
Battery disconnect switch in off position.
Blown reverse polarity fuses in converter. Check first!
Fuse or circuit breaker near battery (hmm, dont see one).
Fuse in 12 volt dc panel (good, as I said I can switch it on and off and it controls the 3 prong outlet next to the converter/charger and the convert/charger will go off and on as I do so
Battery disconnect switch is on positon
Fuses in converter are good, tested them with multimeter too.
