kemeisland's avatar
kemeisland
Coach battery seems drained after using generator.
Hello RV'ers!
I'm a few weeks in to full-timing, in my '89 Mallard RV. I got the Onan generator working, finally, and realized that to use it I need to plug my 30-amp hookup into a jack in the power hookup compartment.
When I run the generator, afterward the Test Panel is completely dead, the Propane powered fridge shuts off, and in general everything behaves like there is absolutely no power in the house battery. So I run the engine for a bit, and within a few minutes usually, everything comes back on.
I'm wondering how I can avoid this. It can't be healthy for the electrical system. When I try to shutoff the 30-amp breaker before I turn off the generator, it doesn't seem to help. I don't know if it is actually helping to unplug the 30-amp hookup from the generator power outlet, but I do.
I'd like to keep the 30-amp hookup plugged into the generator outlet most of the time, so I can use the generator periodically without getting out and attaching the coach to the generator in the power compartment.
Any help would be much appreciated!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
