GrouchyOldMan
Dec 02, 2017Explorer II
Thanks for the quick reply. I have already checked all of the fuses that indicated "Trailer" because that seemed a likely candidate but none of those fuses were blown. The RV also has a wiring harness and plug for adding a trailer, so I figured that's what those fuses were for.
I don't think the grounding could be the problem because the same ground wire is used for the back and turn signal light.
It is so odd that the turn sigs and backup lights work fine because those lights are part of the same tail light assembly (Command Electronics 03-30).
I didn't notice any fuses labelled "Tow" but I'll look again.
Perplexed...
Perplexed...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
