dougrainer
Dec 02, 2017Nomad
Have you checked the fuse box up front by the engine? There a 2 fuse boxes. The engine area fuse box and the fuse box inside by the drivers feet. I NEVER pull and visual check a fuse regardless of what I do. I ALWAYS use either a Voltmeter or 99 percent of the time a 12 volt test light. With RV's, you can never assume that the fuse that is labeled for the appliance you are troubleshooting is the correct fuse for your defect. Within 5 minutes, I can have all the fuses tested and verified which ones are good and which ones are bad. Also, they SEPERATE the "trailer" section from the main body. They have done that for almost 20 years. They decided that if you have a short in the tow/trailer system, you do NOT want that to kill your main lighting also. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
