drsteve
Dec 02, 2017Explorer
GrouchyOldMan wrote:
Hi Doug, thanks for the helpful tips.
I have checked both fuse boxes and looked at every fuse related to lights or "Trailer," but there were none that were obviously blown.
Your comments about using a Voltmeter is valuable. From past experience I just figured that I could tell visually if the fuse was burned out and none of the ones I checked looked bad. I assume you use the meter to check continuity across the fuse?
Do you have a method of testing them without actually removing the fuse? The "Five Minute Method" would be a lifesaver!
Regards,
-Grouchy
Get a 12v test light, $5 at any auto parts store. Test procedure for fuses is shown in this YouTube vid:
Clicky
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
