dougrainer
Jul 30, 2020Nomad
kellem wrote:dougrainer wrote:
The only other possibility is, Your Toilet water valve dump blade was stuck slightly open and when you were filling the Fresh Water, the water was going into the Black tank thru the toilet. Maybe that is why it took a long time to fill the Fresh tank. Doug
Solid theory but the dump valve being stuck slightly open " happens quite often " shouldn't allow the toilet to continue to flush but must admit......I'm stumped if hose was indeed hooked to fresh water.
NOT DUMP VALVE. The DOWN knife or ball in the toilet that seals the toilet bowl from the tank. That opens when you flush the toilet. Doug
