DavidRue's avatar
DavidRue
Coachmen Leprechaun fresh water tank
I have a 2018 Coachmen Leoprechaun 21QB. Have taken many trips. Recently I filled my fresh water tank, waiting in the driveway for it to fill. When I heard the overflow water running onto the driveway, I looked underneath and it seem water was also splashing out of somewhere right by the overflow drain tube. Shut off the water and didn't think much of it. I did not use the presurre regulator like I usually do. Later in the day while on our trip I discovered that the water tank was completely empty. (drain valves were shut tight) Also, the black water tank that was emply when I left was now full of water.
As I drove to destination, I spent the whole time worrying about did I split my water tank of bust a pipe somewhere? I was so worried about a major repair needed. Arrived destination that day, and immediately went to work diagnosing. I filled water tank with a hose, until the overflow started running onto the ground and shut off hose. NO leaks anywhere, all normal. For 4 days now I have used the fresh water system (and I had drained black tank). Water pump on full time during the 4 days. Only thing I thought was odd is that when I filled tank at my destination, when it began to overflow, the overflow ran for a while onto ground after hose shut off- about 3-5 gallons flowed out. But all seems normal now. All plumbing, pump, heater, etc. work fine.
SO, what on earth happened at beginning of trip when fresh tank emptied from full, and black tank went from empty to full of water, and all seems perfect now??? Thank Dave
  • What happened was simple. Some RV's the overflow tube IF when overfilling and water comes out the overflow tube, it starts a SIPHON. When you shut the water OFF, the siphon continues until the water reaches a level where air can then interrupt the process. BUT, this is IF you connected to the Water FILL port. What you did was, you connected to the BLACK TANK FLUSH by mistake. Luckily, the top of the tank is NOT sealed correctly and the overflow ran off the top of the tank. OR, most common, you have "POPPED" the 3 inch toilet down pipe that goes from the toilet to the top of the tank LOOSE and the 3 inch down pipe is NOT sealed to the tank. You can sometimes see this when looking down the toilet with the toilet valve OPEN and no water running. I would flush the tank a few times and then refill the tank with the Black tank flush and monitor the liquid level by watching thru the toilet> have someone outside to turn OFF the water when the water comes UP that 3 inch pipe. If the water does NOT come up that 3 inch pipe the downpipe is not connected to the top of the tank and you will get odors since the tank is not sealed correctly. Doug
  • Happened to us one time when the toilet valve did not close completely, letting fresh water into the toilet, until the bowl filled, then via overflow into the black tank. Might watch for that.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
