Bumpyroad wrote:
TeryT wrote:
Bumpyroad wrote:
I'd look into rhino lining et.al myself.
bumpy
Thanks. So it looks like that product is just a few years old. Have you used it? It says it can keep the RV "up to 20 degrees cooler."
Does it have to be professionally applied, since it's a spray on?
Also, any idea of cost?
Rhino Lining RV Roof
I haven't used it but do a search, lots of previous discussion.
makes a permanent fix, not a band aid.
bumpy
A previous quote said this about Rhino:
ktmrfs wrote:
myself and several others have put rhino/linex etc. over plywood decking in toyhaulers and cargo trailers. We all have mixed feeling on it. Unlike in a truck bed, adhesion is not a strong point. while it's almost impossible to get these off a scuffed up metal base, over plywood adhesion is marginal. if it starts to come loose at an edge it is not hard at all to pull it off by hand. Thats after the installers claimed they have specific directions from rhino/linex etc. on how to install over plywood and it will stick as well as a truck bed.
yes it makes a good floor coating, easy to clean, great for toyhaulers, etc. but we all have to be careful about adhesion issues.
In all the cases it seemed to adhere real well for a few years, then after temp cycling, vibration etc. lifting at the corners
Found on this page
