musicman54ExplorerNov 21, 2013cold water heaterits going to be in the 20s this weekend while we are out does it take longer for the waterheater to work when its cold out or does it matter thanks
Old-BiscuitExplorer IIINov 21, 2013Recovery rates are based on 70*F inlet water temp.......So the lower the inlet temp the longer the recovery rate.Turn it on and then when you break camp turn it off
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.cold temps and water heater?
