mchero
Jun 23, 2015Explorer
Rheo1
Please tell us the make/model of your water heater.
Some of the higher end Atwood hot water heaters heat the water to 180 deg. and mix that 180 deg. water with cold water via a mixing valve on the rear of the HWH. Their is also a winterize valve on the back of the hot water heater. This mixing vale can stick giving you either scalding hot water,lukewarm or cold.
Also..... remove ALL airators (spelling?) on each faucet and/or spraw wands. I was amazed at the amount of garbage that collects behind them. Put them back on when cleaned. They help save water.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
