- MooneyAviatorExplorerok, the numbers on my relay are not the same on the diagram though, does that matter? Should I go by number, or by position on the relay?
- C_SchomerExplorerYour diagram shows the start kit and it uses the common potential relay numbering. 5-2-1 = common-start-run. Doesn't your relay have 5,2 and 1 on it? If not, you can ohm it and determine the coil and contact terminals. Craig
I found this doing a search
http://www.google.com/imgres?imgurl=http://neilorme.com/pics/potential.relay.ladder.jpg&imgrefurl=http://neilorme.com/csr_motor.shtml&h=725&w=800&sz=38&tbnid=l6EikUUyYVKQUM:&tbnh=90&tbnw=99&zoom=1&usg=__11GkUjHSo4TvIxI-RfJRE9jH-ic=&docid=hSKrI--obhuusM&sa=X&ei=5wU2Uq7eHqiPiALq0oHwCQ&ved=0CIEBEPUBMAc&dur=3802 - MooneyAviatorExplorerit has the numbers, they are just in a different position as the picture on my trailer is all.
and Im not sure what that pic shows you posted, I guess I don't fully understand the connections on this thing, sorry.
I know the relay is simple, just not sure what way the power should be going through everything.
And on the new cap, does it matter what side of it is hooked to what? it has no markings on the terminals - Chris_BryantExplorer IIGo by the numbers over the position- as long as they are 1 2 and 5.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
