wa8yxm
Aug 22, 2020Explorer III
If it is the starter relay (actually the run relay) there will be no voltage on the compressor leads.
Most any relay capable of operating a motor at 20 amps 120 volts will work. it may not fit on the board (you may need to "Remote" it with jumper leads.
But any relay designed to run a 2 HP motor should work.
Might be able to use a smaller one (I tend to use components on the "Heavy duty" side of life to avoid overload)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
