wa8yxm
Jul 12, 2014Explorer III
If the roof A/C is icing then
1: Clean intake filters inside the RV
2: Clean evaporator coils if needed (NOTE: you have to go topside to do this but you can inspect them from below while cleaning filters)
3: Clean CONDENSER coils.. (Might as well).
4: Run fan on HIGH
5: Check for the frost sensor.. this is a probe that on SOME models is stuck into the evaporator coils, near the bottom.. I have read of cases where it was lying in the drip tray and absolutly not working.. NOTE: NOT ALL A/C's have this,, But if yours does, it should be stuck in the evaporator coils.
Side note: One of my Carrier units was tripping its 20 amp breaker.. I went topside yesterday and cleaned the condenser. So far, the breaker has held.
4: Run fan on HIGH
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
