MrWizard
Jul 12, 2014Moderator
remove roof shroud clean drain pan and hose, make sure drain is open, blow dust out of Everything
run fan on high..
with shroud off run A/C make sure condensation is running out of drain pan onto roof
if its not draining, it fills up, blower will pick it up and the moisture freezes on the coils
run a/c fan on high you Must move Lots of air to keep coils dry
run fan on high..
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
