Revconguy
Nov 16, 2014Explorer
Coleman Mach-3 AC Gasket
I have a Coleman Mach-3 AC unit that has a leaking gasket. I'm a little on the heavy side (big boned) ;) and am reluctant to get on te roof out of fear of breaking something. Is there any way to replace the gasket from inside of the unit? It looks like all you have to do is remove the 4 mounting bolts, disconnect the power, and the AC should lift up. Some specs I read indicate that it weighs about 85 pounds. I should be able to push that weight up from below to raise the AC up.
Has anybody tried replacing their AC gaskets from below?
thanks...B
thanks...B
