wa8yxm
Jul 09, 2019Explorer III
First on Colemans you do not need to remove the sheet metal cover to clean the condenser. Colemans suck so the crud collects on the OUTSIDE and all you need remove is the outer shroud.
Sounds like yo knocked a wire loose but how you did that I don't know as there are no wires near the area you were working on
Check all plugs and connections.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
